How do I setup ssh on Windows?
SSH and Windows
If you do not have an ssh client, you need to install one.
Putty is the prefered client. You can download the Windows installer
from the
putty web site
(more convenient than install each piece of software one by one).
If you do not have sufficient privileges to install
it, ask your system administrator to install it for you.
Create your ssh key
Run the puttygen.exe utility
to generate a pair of private/public keys.
Make sure the SSH-2 RSA parameter is selected at the
bottom of the window and click on the Generate button.
Once you have accumulated enough entropy, the application
generates the key.
Make sure you enter a lengthy passphrase in the Key passphrase
field and confirm it in the Confirm passphrase field.
Click on the Save private key button to save your private
key in a file.
With your mouse, select the content of the box labeled Public
key for pasting into OpenSSH authorized_keys file, copy it
(that is, hit Control-C).
Make it available for PuTTY-compliant applications
- Under Session , enter the hostname of the Unix machine, and choose the SSH protocol
- Under Connection > Data , enter your login name for the Unix machine in Auto-login username
- Under Connection > SSH > Auth , select the filename of the private key that you saved out of PuTTYGen
- Back under Session , enter the hostname again in the box under Saved Sessions and click Save
This is now added into the registry and all PuTTY applications are aware of it.
Update your gforge account
Paste your public key in the gforge website. To do this,
you need to go to your
account and then go to the Account
maintainance tab. At the bottom of the Account
maintainance tab, you should see a Shell Account Information
section which contains an [Edit
keys] link. Paste (that is, hit control-V) your public
key(s) in the empty field below and click the Update button.
Warning!
A common problem is that the Shell Account Information field
does not appear in your account page. This usually happens
because you do not belong to any gforge project. To correct
this problem, either create your own project first or request
the project admin of the project you want to join to add you
to the list of the project's contributors.
Please, be aware that uploading your ssh public key on the
server will not allow you to connect to the server immediately
through ssh. To do so, you will need to wait at most 24h.
If your connection is impossible 24h later, please, contact
the server administrators.
Load your key
pageant is
a utility that loads ssh keys in memory. If you load your
ssh key with pageant, you won't have to type your ssh
key passphrase again and again.
First, run pageant.exe. Then load your ssh key by right-clicking
on the pageant icon in the system tray bar as shown below.
Click on the Add key menu item: a file dialog pops up.
Select the private key file you saved while running puttygen.exe and
click on the Open button: a new dialog pops up. Its title is
Pageant: enter passphrase.
Type in your passphrase and click on the ok button.
Your key is now loaded in pageant.
You can now access your UNIX shell account located on the
gforge.inria.fr server or use your source code management (scm) repository.
Detailed instructions on how to access your SCM with the tortoise graphical
user interface on windows are available here.
